944cabby
Since the winter has set in it's fair to say that i haven't used my cab a great deal other than making sure i take her out at least 2 or 3 times per week albeit most of the journeys fairly short.
It's stored under my car-port and covered when not in use.
Now as i've not been using her a great deal since the end of summer whenever i check my oil cap there's usually water droplets and a milky substance in the cap and the same down the tube.
The dipstick is always fine - ie nice golden oil, no other contaminants and on my last oil changes there have been no signs of water contamination.
I usually leave her to warm up before i drive off but i've not driven her any long distances lately.
I'm hoping that it's just condensation through lack of use and not the headgasket going.
She drives fine, pulls great and i've checked the plugs and they seem a little sooty around the edge but other than that quite normal.
Are any other '44 owners experiencing similar symptoms through lack of use and cold, damp weather.
One thing i have noticed is that the oil filler cap is very loose fitting right up to the last turn, so would a worn filler cap or "o" ring allow the condensation in.
In normal weather she smokes white a little but soon goes when waming up but it smokes longer during very cold weather.
If it were the headgasket going would you expect to see the oil filler cap gunky even after long journeys?
Any thoughts or am i being a bit paranoid.
