CONDENSATION PROBLEM
- Thread starter Guest
I tried driving with the A/C off on last journey and put the windows down for a couple of minutes, and so far it hasn't misted back up, so maybe this is the same as you ?
Also, as above, leave the car wide open if you can.
Some ppl (Honest John) recomend running full hot for a while to rid pipes of moisture -I'm not sure about this as I've had major steam up probs after!!!
Run the aircon flat out cold for a while. The drier should remove any dampness.
The fast clear button also runs the aircon to dry the air out.
To be honest, I can't see how using the aircon would increase condensation unless the drain off pipe is blocked and its leaking condensed vapour (water) back into the car.
944's do have sundry places where they like to leak and wet areas may not only be the carpet. Rear seats, head linings, rear side panels and boot wells are all areas which can harbour damp without being obvious.
Diver944
If there's no leaks then it just sounds like general dampness and regular running with the heater and fan on full should improve it. The S2 heater is awesome and after just a few miles can turn the interior into a furnace []
Mel
Check the numerous drain tubes... even the one for the filler cap is a s*d.
I found 2 blocked (sunroof), 1 kinked and detached (filler cap) and don't forget the door bottom drain holes (take a speaker out and check behind for signs of damp). Check your boot wells to make sure plugs are ok and dont forget the main culprit - the rear hatch rubber seal - easy and cheap to replace.
I did all those and it was drizabone[]
