Condensation?
- Thread starter channella
Had it too. Keep an eye on it, it could be to do with two things...
1. The o-ring on your water cap has worn/perished and as its a pressuried cooling system, you are losing coolant there, hence the condensation.
2. Tighten the cap! I really had to give it some welly to make sure I did lose coolant.
Eventually the collant warning light will go on as you can lose a surprising large amount of coolant through a loose/illfitting cap.
cheers,
Iain
