Condenser Replacement
- Thread starter Costelles
You can save money by using a pattern part but the quality is noticeably poorer. This might be an acceptable compromise if you don't have a long term view with the car, or that it's unlikely to see bad weather.
I do normally say that OE o-rings are worth paying the extra for. These never leak, whereas the patten parts can be hit and miss.
Lastly make sure you get it de/regassed correctly. The AC system on your car requires a lot of oil in it - of the order of 200ml. It should be vacuumed for 30mins as well. Your average Kwikfit may not check / cut corners.
KR Lee
Gordon Attar
