chrono
Hi all
Another two questions for the Boxster boffs out there (big respect for your knowledge dudes - I'm only learning):
1. Roof motor intimitantcy:
My Boxsters soft top motor is causing a little confusion. When I've been driving it and then want to stop the car and raise/lower the roof, I pull over and with the engine running, press the button. It yields nothing. If I stop the engine and restart, the motor works fine. The garage who sold me the car said that a) once I had started pressing the button I was to keep going until the movement is fully finished otherwise the hood would "get a bit confused". This tends to agree with the manual, but do other folks have to stop and re-start their engines to get it to work after periods of driving? Is this normal? Is the intermittancy a result of my poor cars "confusion"?
2. Oil countdown timer on dash:
Also, when starting from cold or after a short period, the oil timer on the dash counts down from about 5 seconds, during which I wait until it finishes before starting the engine. If you stop the car briefly (as mentioned above, or you park up for a minute then get back in) then restart, the oil countdown can read as much as 40 minutes!! There's no way I can sit on the side of the road for 40 minutes! The amount of time varies greatly when the engine is warm. Why is this? Does it do any harm to ignore it?
Thanks for your time and deliberation. I'm loving every minute in my car. The owners club definitely seems worth joining with you lot around! [
