I have been reading up on various sites on the net, how to connect a charger to a 981 boxster,and have found loads of info etc,using my car I thought I would look into it in more detail,what I saw on net and what a found out using my car,i am a sparky by trade,25 years working on dyno test cells,and car electrics .on the 981 boxster I found that after locking doors with key fob all power sockets are switched off after 30 mins,(to test this I used a power adaptor 12v ,3 way socket with a usb output and a 12v phone charger adaptor X2) after 30 minutes the sockets powered down when these were connected.looking on sites on the net it said you had to connect a charger to the + terminal on the battery and -ive body work of car(not -ive on battery as this will damage battery monitoring system on car ,Porsche sell a lead for this £20) . what I read on the net also was that
The vehicle's 12V sockets are deactivated if no charge is
applied for 30 minutes to protect the vehicle battery.
• Turn vehicle ignition on and off once before charging if the
ignition has been turned off for more than 30 minutes.
• Switch on the vehicle ignition once after the charger has
been disconnected for more than 30 minutes, e.g. through
a power cut.
what I found was that when I connected a charger to a power socket and powered up with in 30 minutes ,that socket would remain live as long as the power from charger was connected and if the charger lost power the car would switch the socket off in 30 minutes as it states above, (for some reason my smart charger was switching off after 30 minutes(lidl charger) ,my Porsche charger would not switch off after 30 minutes so I am using this now) I have now built my own charger using a 12volt, 0.8 amp psu and a solar panel controller module, and it works fine. reading on the net I also found out that if you fit a new battery to the 981,you have to tell the car a new battery has been fitted.(bmw have done this for over 10 years)
so what I have found is you can connect a charger to a power socket in a 981 boxster as long as it done within 30 minutes of locking doors,and if you leave a 12v adaptor in a power socket in the car it will shut down after 30 minutes,and when you open the doors with key fob it will repower back up.
added: the 981 boxster and cayman use a agm battery that has to be charged at a higher voltage 14.4v that's why Porsche sell 2 types of battery chargers,i have found out you can use the snowflake(winter) settings on other smartchargers ctek and others
a power cut.
