CONSTANT TICKING NOISE FROM ENGINE
- Thread starter reevers
adrian996
Adrian.
I too found that a 5W-40 or 10W-40 helped a great deal in reducing the occasional start-up clatter common on the 996. Rightly or wronly, I put it down to the fact that the oil doesn't drain down as quickly overnight.
The '40' is just an SAE rating to classify oils within a viscosity range. To make a direct comparison, you need to compare the absolute viscosity (in Centistokes) of different oils at the same temperature. '40' refers to a band of between around 12-16 Centistokes at 100°C, so there can be a large difference in viscosity between two '40' oils. Mobil 1 and Magnatec -40 oils have very similar viscosities at 100°C, but Magnatec is slightly "thicker".
Black80XSA
I know of two other similar incidents, where a blocked oil hole/channel in the tappet led to camshaft wear and a sudden increase in noise level - both these were on MY03 2.7 Boxsters
