Coolant bubbling
- Thread starter stevespic
I'm having a few coolant worries at the moment, but am gonna start with a new cap....
ORIGINAL: sawood12
..... the fuel scavange system. There is a small pump that runs after you switch off and pumps fuel from the fuel rail back into the fuel tank. .......
Damn, you learn something new every day. Why do you get covered in fuel when you take the pipes off the fuel rail then?
peanut
never heard of a secondary fuel pump ? what models is that on then ?
re the bubbling sound it could be air in the system due to the split but I would make certain that the electric radiator fan is still running for 10 minutes or so when you switch off the engine . If it doesn't the engine temperature continues to rise several minutes after you switch off. The increased pressure can cause bubbling sound in the pipes and heater radiator.
When this happened to me, soon afterwards my head gasket went ! £0000000 so I would strongly advise you check out your radiator sensor, fuse and fan operation
ORIGINAL: peanut
....never heard of a secondary fuel pump ? what models is that on then ?....
Quite! [8|]
sawood12
ORIGINAL: John Sims
ORIGINAL: sawood12
Because it only relieves the pressure in the fuel rail and doesn't totally evacuate the fuel pipes leaving them primed for the next start up. That's why you have two fuel pipes, one is the return pipe. You have to really listen out for it. I heard it once when the car was parked uphill and I could hear the pump and the scavanged fuel actually tinkling as it drained into the fuel tank behind me. I had to pop off to the toilet shortly after!
peanut
I switched the engine off and could hear the engine tinkling but no fans ? ( mine has 2x fans like the turbo )
When I switched the ignition to aux sure enough both fans fire up big time like a helicopter.
Shouldn't they be direct fed from the battery so they run after switch off until the rad sensor switches them off ? Otherwise whats the point ?
sawood12
