Coolant in S2
- Thread starter colin944
Craigybaby
This is pretty much exactly my experience (apart from the cracked cylinder head).PhilKent said:I've had slightly declining coolant level since I've owned the car (about 15 years now). It's a turbo not an S2 but my thoughts, having nut and bolt stripped the entire engine, coolant system etc, die tested the cylinder head etc (I did have a cracked cylinder head at one time many moons ago), is that it's normal. I suspect the vent system is working sometimes and hence the level declines very slightly over time. I guess it depends how bad it is, but I tend to check and top up every few thousand miles...I've used both pink and blue, but never mixed, no difference, no issues with either...
Use pink or blue/green. Don't mix them. Keep it topped up. That's about it.
Craigybaby
jonnyporsche
