kasspa
Hi Rod,
Not sure if this has any bearing on your issue but my 996 4S recently developed a leak on the drivers side metal coolant pipe that runs pretty much back to front.
It was 'pooling' behind o/s front wheel, running off undertray.
I would imagine any camber would cause it to run toward the other side.
The pinhole leak was just behind where the hose is clamped to the pipe, at a push the hose could be stretched to cover it & clamped with an additional jubilee clip but I was worried about the stresses it would create elsewhere, so replaced it.
hth
hth
