coolant leakage
Parked my 996 to find coolant leaking out the back of the car. On further inspection it seems that i have coolant leaking out of the bottom of the tank. Very annoying as the AA couldnt fix it and the car had to be towed away. Was wondering if anyone else has had this problem?
Simon
No experience of what you describe. In the absence of any other comments there may be something here (kiv cut and paste all the address)
http://www.pca.org/tech/tech_qa_question.asp?id={A452CCE7-DCE0-4497-8BE5-35044F4B0C8C}
Hope it helps,
I opened my garage to find two puddles about 50mm Sq x3mm deep.Not much
Could see it'd run off the exhausts.
I took it too the OPC who checked it -all OK.
Realised I'd had left the car facing uphill canted to right after a long run.
Then given it a wash.
I reckon it just pushed a bit out under pressure.
It been Ok since.
Note its easy to cross thread the cap if you remove it when cold
