Coles
Yesterday afternoon I arrived at my lockup garage after a 25 mile drive and after pulling into the garage a flood of coolant began pouring out near the rear offside wheel. It eventually stopped but there must have been a gallon or more of coolant over the floor. My thought was that a hose had split. I arranged with my insurer for the car to be recovered to Portsmouth OPC next day. However, the recovery guy had a look around the car and topped up the system with water and asked me to run the engine. The engine got up to temperature and stayed on 80 and there was no further coolant loss. He said that the filler cap was faulty and not sealing airtight which was not allowing pressure to build as it should as the coolant temperature rose. Coolant was overflowing past the cap and down the overflow pipe. Hence the water on the boot lid which I had noticed before but thought was just minimal evaporation. The car is now in OPC for a new filler cap and flush and refill with coolant. The lesson I have learned is to make sure the filler cap is screwed tight, to look out for condensation on the inside of the boot lid above the filler and to replace the filler cap if it is likely to be faulty.
But I will see what the OPC say on Monday.
