coolant !!
guychris
happy new year to everyone....i have just noticed my coolant level looking really low!! not sure for how long now, could this damage the car? and am i ok to simple buy some and put it in.....or should a pro deal with it.....any advice needed....thanks.
If you top it up to maximum & it quickly loses some but then levels off that's normal. Mine sits just above minimum normally, if I top it up it just pushes it out until it gets back to it's normal level.
You just need to watch it over a period of time & get used to your own car's foibles.
otoh if it's losing water constantly & overheating there may be a problem.
you shouldn't lose any really. I have not topped mine up in over 3000 miles.
I would suggest you monitor very carefully. Check under car after a run see if there is any leakage. Check around your hoses .
It would definitly be worth asking your local garage to do a `leak down test' where they pressureize your coolant system via the top up cap and check for pressure leakage .
Keep an eye on your temp which should hardly ever rise above the first mark this weather.
If you have a leak it could be due to lots of things including leaking hoses, heater matrix, radiator, faulty rad cap and possibly head gasket which would cause the coolant system to over-pressurize and force water out of the filler cap overflow pipe.
Might be worth fitting a small plastic container on the end of the tube see if it collects any water.Check your exhaust after starting from cold if there is a lot of white smoke it could indicate a head gasket problem
thanks guys, there is white smoke but only after a minute or so when the engine warms....i hope this is normal?? i have topped up the coolant this evening and ill monitor it overnight....fingers crossed....thanks again.
I've got a pinhole in a hose that you'd never find when cold, but when hot sqirts water out nicely. Also had a leak that never hit the floor as it gathered on the undertray and flew off when moving, so be aware that you might have to look hard for a small leak!
I used to top mine up several times a week until I read a post on this forum that stated that on his car the level stabilised at just over minimum when cold but closer to maximum when the pressure was still there.
I tried it and I have never had to top up again. That was best part of a year ago.
hey guys, after filling it up last night, i have taken a look this morning and its sitting just a tad over the maximum mark......seems ok.....im going for a run in her later......fingers crossed...
