Cooler Plugs
- Thread starter 944Turbo
Kevin Welch
I believe the difference with the plugs is the diameter of the central core. This dissipates the heat to keep the plug within its ideal working range. For you boostie boys this means higher boost equals higher internal temperatures thus the need for a colder grade of plug ( which runs cooler ) to remain at its optimum.
Us normally aspirated chaps keep our cool anyway.
Can you remember what ones Danno reccomended?
Slim,
Danno recommended -
"Use one-range colder spark-plugs: NGK-BPR7ES, ND-W22EPR-U, Bosch-WR6DC"
I assume ND (2nd option) is Nippon Denso
Tony
ORIGINAL: Fen
I can't explain what the difference is, but plugs all have a number - I remember BP9ES for some reason. The 9 refers to the heat. I think a BP8ES was 1 grade cooler, but I don't remember what engine it was for. 1700 x-flow perhaps? Anyhow, the principal is the same, but I'm ashamed to say I have never bought 944 plugs - I've always paid someone else to fit them for me - so I don't know the specific numbers.
Fen its the other way about the higher the number the cooler the plug..
BTW I think the point is that higher boost increases the temperature in the combustion chamber which obviously makes it hotter for the plug tip. Cooler plugs cope with that better, so you probably should run a grade cooler if Danno says it's recommended - if your plug gets too hot it may not spark efficiently or it may even cause detonation by being a hot spot in the chamber. The general rule I always thought was that you cool the plug if you do anything significant to up performance like increase CR or fit a hot cam - I'm sure that goes for increasing the boost as well.
Diver944
Maybe these are a cooler plug?. I'd better call Andrew (Promax) when he returns from the States
There is also additional heat created by the hotter charge (due to being compressed more - upgrading the intercooler is the only way to help here) and that sueezing more air in and then adding the fuel to suit results in burning more mixture which releases more energy, hence more power but also more heat, to be considered.
I have just bought some cooler plugs will fit them on Sunday. NGK BPR7E v-grooves. I would rather err on the cool side, long term its much better for your engine.
The plugs i took out were only in about 2500miles so they are hardly used, just starting to go that light brown colour, so looks like the fueling is ok.
The ones i fitted arnt the very best ones, but i am pretty sure that the car is ideling better, much more consistant less hunting.
Time will tell about the difference they make, i am going to order some Iridium NGKs from the US.. $30 and they are £35 over here!! Will leave the ones i have in for about 3000miles till next service then change them and have a look see if there is much difference.
Ordered 6mm cotton braided fuel hose to connect the wastegate to the Accuboost so will get tha done next week with the exhaust. Then its time to try and calibrate the Accuboost. I am sure i migh be getting some boost spikes with it connected though the CV.
