white944
White944 is an 85.5 with a single cooling fan and conventional sized relay rather than the double one. The fan doesn't work, and I've traced the fault to an open circuit between the fan switch and pin TS (the small pin) on the relay. If I run an extra wire to bypass the existing circuit it all works fine. So.... I appear to have a problem at the fuse board. Before I pull it apart, do they suffer from internal faults? Anything common I should look for?
Thanks.[
Thanks.[
