Cooling Fan?
Horsesoldiers
Hi it just occurred to me I have never heard the fan on my 2005 C2S, temperature always spot on and never moves once warmed up. When should the fan kick in and is there just one fan?
Morning!
Nothing to worry about. You’ll never hear the fans unless the car either gets really hot with the air con running as well, or if one fails and the other one has to work harder. (You’ll know if it does, it sounds like a jet engine on takeoff)
That kind of answers your second question too - there is one fan on each side of the car. Put your hand next to the side indicator when the cars running and you should feel heat venting from inside the wheelarch.
In normal driving the fans run but are nearly silent. As most engine cooling need is provided by air coming in as the car is moving, the fans only need to work a little as the car slows it stops.
When you’ve got the air con on, the fans run constantly but again, it’s usually pretty quiet.
Hope this helps!
Thanks for the reply. Yes warm air from the wheel arches after a "spirited” drive is normal so I guess all is fine. Many thanks
