Cooling Fans, rebuild or renew.
Paul190H
Afternoon guys, has anymone rebuilt the cooling fans on an S2 or replaced? Got from OPC is around £250 ea + the dreaded VAT. Any advice would be welcolmed.
My thoughts on cooling fans would be:
1.Fan & electric motor design has significantly improved in the last 30+ yrs. New fans are cheaper more efficient and draw less current. If u just want to cool the engine water look at other options either using the original shroud/ duct or one that comes with the fan.
2. If u wish to retain orginality yes I could buy new, much more cost effective to have the motor rebuilt, new bearings n carbon brushes etc.
3. How old is the radiator/ how many miles has it done ? They get very clogged up internally and externally and lose cooling efficiency.
Oh and ref the original question I haven't had to sort my single fan ( dropped one fan off for flow thru speed cooling) in addition to another oil cooler.
Chris
Thank you guys, mine both work but one has a really screechy bearing so I have disconnected. I will look at non original options. Not sure how old the rad is but gave it a good flush through when I got the car.
Cheers and have a good weekend.
oh those are nice but prob work out more expensive than oem, once you add on duty, shipping etc.
MIT be worth seeing if the bearing can be replaced, most like a BMW or Audi or vw part.
Them alloy fans look nice? "Porsche don't need cooling over 35mph" do they think are engines are in the back? I.e air cooled? Can see where are rads are any differnt to other cars
I assue they mean that the 944 doesnt require aux cooling in addition to the radiator over 35mph, makes sense to me.
