Joss Walker
Hi guys
I need help from someone with a greater understanding than mine (shouldn't be too tricky)
Took my car (91 S2) to work yesterday, I haven't driven it on any long runs for a few years now (!!!) so 90 odd miles on the M1 and M25 each way and I had overheating problems. If I didn't keep the heating on full then my needle moved right up into the bottom of the red zone, even with the heating on it kept moving up and down between a dead horizontal position and up to almost touching the red, and this was fluctuating every minute or so the whole journey home.
Coolant is at appropriate levels and doesn't seem to leak at all, I just undid the bleed screw (with heater turned to high heat but engine not running) and the only thing that ran out was coolant. Water pump was replaced about three years (probably 1,000 miles) ago.
Any suggestions what the problems may be? I want to drive it all the time with this weather but am anxious about any long journeys
Joss
Joss
