After a fast run with the Turbo the other night, the fans came on after I switched the engine off for about 10/15 minutes & the next morning had a bit of white smoke when I started it. Is this normal for the fans to start after the ignition is off? will it drain the battery? should I get worried about the smoke? Should I let the car idle for a while for the Turbos to cool off before switching off? also is it better to warm up the engine for a few minutes in the garage before driving or start driving gently on a cold engine?
All advise welcome...
Francois
Francois
