Cornering light - bulb replacement
Cayenneman
Does the headlight cluster actually have to come out to replace this H3 bulb? The handbook isn't very clear but suggests that!
Took the headlight out of mine today ( mine has zenon which may/is different ) an it came out easily. I was having intermittent operation of the LH Indicator bulb. Thought it was the bulb but no the connector was loose. I found a tiny piece of the connector broken off, either I broke it or it was the cause of the roblem. Anyway, it s working now.
