correct procedure for replacing sunroof after taking out?
Just carefully drop it back in and clip the front then I think you can just turn the ignition on and it will latch, although I have always latched it deliberately by turning the key to accessory and pushing the close side of the sunroof button.
You need to make sure that the sunroof is pressed evenly into the recess at the rear as otherwise the legs can miss their holes as they extend, or - worse still - one leg goes in it's reciever and the other goes under the sunroof.
Mine is a bit of a pain as one or more microswitches is out of synch. As a result it doesn't know if the sunroof is in or out or if it is locked. I have to lean back an look up into the receiver to ensure I take my finger off the button when the leg reaches the top of the incline to lock the roof in.
With nice aircon the roof almost never comes out anyway.
