Couple of questions please
ever88
to remove the sunroof an my previous cars, I simply turned ignition key off then pressed for it to go down again and you could hear the motor retract and hey presto lift it out once front catches released.
current oval shape 944 turbo model doesn't seem to play game.
what am I doing wrong?
second question remembered the turbulent air noise when window open. noise massively reduces when you grab wing mirror inside edge. are there deflectors / mods that people may have adapted over the years that look ok?
cheers
Sunroof - fooled me for ages - stick the ignition key in position 1, then do as you were doing before......
Question 2 - no idea !
question 1 as above turn key slowly till fans/radio work - position 1
question 2 - different angles for different speeds, but mine have been stiff enough to maintain the position they are put in,
Tony
