Couple of technical questions regarding engine removal/installation
chrisg
All
for those of you that get your hands dirty ?
1. How do you remove the oil sensor level from the sump on a 951 ? Does the sensor come out completely or does it unclip and that way you can remove the wiring harness ?
2. Reinstalling the engine, exhaust manifolds on or off ? If off, can you refit them with the studs in place ?
thanks
Chris (20 mins from removing the 951 engine.....)
Just out of interest- are you removing the engine from above or below?? The Haines manual says remove from below.
BTW- please post pictures and some description as to how you got on!
WIll do, once I get to the stage of actually taking it out !
I'm at the stage where the block (cam tower & head off already) is suspended at the front by an engine/gearbox bar and supported from underneath via the sump at the back.
Next step, remove the rest of the wiring harness - hence the question regarding the level sensor, attach the engine crane and out we go.....
Not forgetting to remove the 4 bolts that hold the bellhousing to the torque tube !
When you re install your engine put the manifolds on first. I tried fitting my engine with the manifolds off and had a VERY torrid time.
Ian
thanks for the advice. The engine has now been out for ~ 2 weeks and the block is on an engine stand.
Do you know how bleeding heavy a 951 crankshaft is ?
C
Yep, I do!
With the engine on a stand I used an engine crane to support and gently lower the crank in for checking bearings etc. It sounds like overkill, but it was a hell of a lot easier.
Regards,
Tref.
