Mr.FixitNorm
I was checking out under the front nearside of my car today to try and establish why my `ice warning' sensor was saying it was 26 deg.C !!! when I spotted two things which gave me more concern than the sensor. The first was the long stabiliser bar mounting bracket which had sheared off at the right angle where it bolts to the chassis, the second was a strange large flexible `heater type' air (?) pipe which was attached to a 60mm plastic pipe which disappeared into the wing behind the wheel arch liner, the other end was attached to a 60mm pipe which turned into a large plastic cowl fitted over the back of the alternator.
The flexible pipe was in a terrible state - split & disintegrated, but I can't fathom what it's for?? I've checked the Official Porsche 944 workshop manual I have in PDF form, and the Haynes manual and I can find no mention or picture of this cowl or pipe system to find out what it is or what it's for.
To cut the story a bit shorter, I removed the front wheel, took off the broken stabiliser bar bracket, cleaned and mig welded it up ( I know I need a new one but the cars a daily driver, my missus was working tonight and I take her to work, and I'm almost certainly going to have to search the net for one ! ), which worked very well.
The flexible pipe I removed was toast and had an internal `cloth? sleeve' which had collapsed so I removed the bits and all I could do was replace it temporarily with a piece of flexible ally pipe which fitted inside the plastic fittings.
Question is, does anyone know what this system does?? I couldn't see what was on the other end of the pipe in the wing and it was getting too dark to take the liner out. I can't think why the back of the alternator needs a piped airflow either.
Any ideas??
Norm
ps never did get to sort out the ice warning sensor[8|]
Any ideas??
Norm
