Hello All,
I had my 996 C2 back from its major service about a month ago - a few oil leaks (vario-cam solenoid, spark-plug tubes & oil-seperator/breather) were sorted out at the same time. Since then it's really just had its feet-up.
I've just been out to give it a run and when back on the drive noticed that when the oil filler cap is removed the engine idle speed is significantly affected, just holding my hand over the filler pipe is enough to alter how the engine runs - is this normal? (had quick scan of FAQ but did'nt notice anything).
Also noticed a small amount of smoking from the right exhaust pipe at tickover, which dissapears after about 10seconds, but then comes back a few minutes later and stays for the same period - no evidence of water usage or contamination. Should I be concerned?
Thanks.
Peter.
1998 996 C2 Tiptronic S
Prev.
1997 993 C2S
2001 Boxster S
1990 964 C2
1977 911 SC
Thanks.
Peter.
Prev.
1997 993 C2S
2001 Boxster S
1990 964 C2
1977 911 SC
