Crank Oil Seal?
- Thread starter the_big_1
If you insist on looking at the car yourself you need to look where the engine and gearbox meet and look for oil residue, a sweat of oil is usually ok but if it as drips it needs doing, the other problem is what is called the intermediate shaft seal which can also leak and give you the same result under the car...
you have numerous thing to look at when buying boxster i.e rads at front are free from leaves and debris, oil leak around gearbox/engine area, your tyres are all n rated and the brakes are all ok and not corroded to death
Black80XSA
Black80XSA
If you look at private cars for sale, check garages and driveways for signs of drips - centre line of car, just ahead of rear axle line.
if you have a lot of oil under a car then assume they are both leaking.
they only way somecan tell if you need a new int shaft is that when they take the seal off the shaft there is play in the shaft bearing,if there is it requires a new shaft which is an engine rebuild.. and costly..
Tool Pants
non Club member but v. knowledgable
berty987
