Black Beauty
I have an on-going issue with a mis-fire/back fire at the mo and I think I have found that it is due to the crank position sensor, but I am not sure how to interpret the resistance readings
When I test the resistance as per the Clarks guide, when the engine is cold the resistance is pretty much to guidelines as is the speed sensor.
However, after going out for a run, the resistance of the crank position sensor is a third of what it should be - what I want to know is, is this normal or should I replace it based upon this evidence.
The speed sensor resistance when hot or cold is relatively the same and well within spec.
Spence
PS I don't know where I would be if it wasn't for the Clarks guide
Spence
