Crank pulley help needed
berg944
I went to change the water pump but I can not remove the 24mm nut from the centre of the steering pump drive pulley on the crank.
I put a large wrench on the pulley (v-belt type) to hold it but the bolt would not move.
Is the 24mm crank bolt a L/H thread ?
Where can I get a flywheel lock from?
Mike
