How do you change the crank seal on a 944 then? I'm finding the clarks garage giude too vague. Ive got as far as removing the woodruff key which is being stubborn. Theres a loose washer behind that and then the same kind of seal thats on the balance shafts. It looks like theres a panel you can remove on the front of the engine.
Ive done the camshaft and both balance shaft seals now so unless its a mammoth effort I might as well do the crank as well. I had a horrible thought that I might have to have the bottom balance shaft housing off to do the crank seal. I do hope thats not the case
