Crazy paint ?
- Thread starter ChrisW
964rsdatabase
65 mat
ORIGINAL: ChrisW
Nobody will mourn the demise of these wheels, but is it only mine that seem to be doing this ?
NOUGAT ???? [:-]
if you get them stripped and apply a good etch primer that "seals" the wheels then my "guess" would be yes. They won't do it again. That said, if you have underlying corrosion(not the most exact term but you get the idea) within the wheel itself then eventually this will break through and blister the surface. The quality of the work in painting the wheel will likely determine the time it takes for the corrosion to re-appear.
