Creaking Centre Console
- Thread starter scam75
TTM
Well-known member
ORIGINAL: scam75
I assume your just stuck with it being the case?
Well, on either of my 944s sometimes it's noisy, sometimes it isn't, sometimes it goes away after pressing the black plastic trim, sometimes it doesn't.
Bit of black magic to me!
pauljmcnulty
So, first you need to find what two parts are rubbing, hence pushing different areas to see what changes the noise. Then, you need to either tighten the two bits so they don't move, or lubricate them so the movement doesn't make a noise.
pauljmcnulty
scam75
Well-known member
I will start to fact find with it tomorrow and report back.
Stuart
Steve - anytime! However, if you never eradicate any noises you won't have to work on each subsequent one that presents itself when a cure for one is found! It is a cause of madness playing this game in a 944!
TTM
Well-known member
ORIGINAL: pauljmcnulty
Just read my previous post. Taken out of context it breaks every rule on the forum and sounds like a bad "Carry On" film! [&:]
Hmmmm... how have your dogs been doing lately?
marcusandrew
scam75
Well-known member
Whilst I was in however I did find a chunk of redundant alarm wiring loom which I have removed (was connected to the blank switch but going nowhere, I thought this was to toggle the interior alarm sensors?) and also re-routed the offending speaker cables so my ashtray now sits flush. [
I think to fix this properly I will have to put something in between the transmission tunnel and the button panel. Not entirely sure though. I can't help thinking they must all creak with the way they are fastened on?
Stuart
