Creaky rear suspension?
apw2512
The roads around Ballymena are just terrible! My 968 sounds like a door opening in a horror movie, CREAK! CREAK! creak! but is fine on the open road - or maybe I just can't hear it!
Rear suspension, nearside! Independent torsion rear suspension (I think!), possibly bearings??? The car's been pretty much laid up over the winter - maybe a good dose of WD40 would solve the problem???
Anybody have any ideas or suggestions?
Peter - in Ballymena, Northern Ireland[FONT=verdana,geneva"][FONT=verdana,geneva"]
Hello Peter,
It may be the rubber bushes at the end ot the torsion tube squeaking but without pulling it apart
I can't think of a way of lubricating it. It could be any number of links in the rear suspension and some form
of lube may help, WD40 may silence things for a short while but is not really a good solution (oil and
rubber are not a good mix) I would try a little investigation, can it be a shock absorber? Is everything as
tight as it should be?
Sorry for not being much help, if the car is laid up for a while it may free up with use.
I'm hoping to have a bit of a dig around this weekend, if the weather improves a bit, to see if I can at least identify where the creak is coming from.
We have a couple of really good guys, Alan and George, here in N.Ire. who could probably sort out the creak - at the moment I'm really looking for ideas!
Many thanks Peter,
Peter!
Amazonas Green 968 coupe, tiptronic!
