smallspeed
Ive got what sounds like a cricket in my heater!.. When I drive along with the fan off I get a cricket type squeak, however if I turn the fan on to any setting it goes away. If Im stopped with the fan on 1, I also get the squeak, however if I turn it to 2 or above, or turn it off it goes away.. Im thinking its the blower fan oscillating and squeaking, but not 100%.. has anyone experienced this before?!.. If not, how can I best go about getting the blower out and giving it a good clean and lube up?.. or is it best left well alone..
Second annoying noise is the snake in the dashboard. It sounds a bit like air escaping, but its inconsistent and only a little bit, just a bit concerned as to what it might be.. wondered if it was the headlight adjuster switch as the adjustment seems to be vacuum based, but setting of the switch doesnt seem to make any difference.. is there a vacuum or air-pressure connection to one of the dials in the dash, or am I imagining the whole menagerie [
ben
ps.. the rest of the car is soooo good that Im picking up on these minor things, which cant be a bad thing [
ben
