Last week while in France I had my cruise control jam ON at 130kph. This could have been quite dangerous. There was no way to disengage, changing down resulted in revs going to limiter, braking to disengage did not work, and using the control lever would not release it. After stopping engine at a Peage, I removed the relevant fuse but again no change. After a number of difficult miles on normal roads, controlling speed with gears and brakes, it gradually released. I suspect the problem is mechanical, cable or motor. I wondered if anyone else has experienced this or knows of a re-call??
Also if you have this option you may also want to get it checked. JZ are investigating next week.
