Cruise control question
- Thread starter Edwill997
Available in different colours/leather etc
Also required if you don’t currently have cruise, wiring harness connection
997 622 674 00
After install, you need get the ecu recoded to recognise it too, either by dealer/Indy or someone with a coding tool
unclewinks
paul
That is from a 996 rennlist forum post, but some of symptoms similar to what you had/have, 9th post from hurdigurdiman lists various symptoms of the different sensors, switches etc. Was the ‘new’ lock you fitted actually new? If it is used maybe it just has a different bad switch to the original one...
