cruise control
well i never i just found out i have cruise i seem to remember the guy when i bought it mentioning it but comp forgot the stork is so short on the colomn easy to miss
how common are these
Paul
Common in the US, rare on any model in the UK. Mine has it.
Push forward to set the speed or hold forward to increase the set speed. Pull back to disengage or hold back to decrease set speed (this doesn't work on mine), push down to resume set speed (only works when you have already set it once since starting the car. Push the prake pedal & that disables it (same as pulling the lever back), dipping the clutch temporarily disables it, re-engage the clutch & it kicks in again.
If you brake for some roadworks on a motorway then at the end hit resume there's quite an entertaining moment as the car pulls the gas pedal away from your foot & uses full power to get back to the set speed [;)]
Mine has Cruise Control....! As said earlier its gr8 criac when the accelerator pedal gets soft....! Make sure the cable to the throttle is not slack for the actuator will rattle as it reaches the end of its travel. If the cable is tight the cruise control will only work at higher speeds [;)]
