CS Beissbarth Target Data?
mcgc0
Don't suppose anyone has a printout or knowledge of what all the CS (target) settings and data are for a Beissbarth measurement and re-check? May whip the car up to Chris at Centre Gravity for some new B6's and H&R springs, probably a SuperPro re-bush too at the same time.
Really depends on what your plans are for the car ie ride height, road v track options etc, as you are going to see Chris he'll talk you through the variables .... IMO no better place.
On the bushes, let Chris give the car the once over, if any are tired he will identify/replace them and I suggest you leave the rest well alone.
I guess where I was coming from Paul is that from a geo set up perspective, as well as knowing where you're coming from (what's your set up now), it's knowing where you are going to and the difference between the two. From previous set ups I've had (by Chriss too), you should be able to get the target data (manufacturer, race etc) to load up and the system will inform the rest.
It's the Porsche factory CS target data I'm after to compare how far (if anything) mine have deviated from (ignoring personal preferences etc). Feeling I'm proabably reaching the stars with this one unless there's some (industry shared) database from all manufacturers.
As you say, Chris can fill in any gaps. However, I do know SuperPro bushes and new mounts really improved things on my 911. Wear and tear comes to all...
