CS oil change ????
m bannon
what oil does everyone use in the 968 CS .
thanks in advance.
just want to give it a quick change, off to the ring next week . ........woooooooooo hooo
5/40 Helix. Recommended to use 5/40 over the usual 0/40 by Opie oils. You get a discount if you need some.
The filter is a pig to get at and spills out all over the engine try when removed so be warned.
yes 5w/40 for me as well, I use Silkolene PRO S -- also recommmended by oilman at OPIE. NB Anything thicker will not do damage but will drain some power away due to excessive crank shear forces.
paul f
