Dekker
I took my car to an open day in late Sept and got it into the garage for a free check.
Found 3 split boots so I'm going to do them all, thats 8 on a C4.
I've read some articles which explain about replacing them on the rears, though there's some debate as to whether the stub axle needs to be removed to facilitate this. A 240ft/lbs nut needs to be slackened on the rear hub if the rear drive shaft is removed to make the process easier.
However no one has mentioned the front ones. If my memory is correct, to remove the front stub axle you destroy the front bearing also.
Has anyone done this or got any advice?
Much appreciated, David.
