robwright
Following a recent post by sulzeruk I got to thinking. If you have a dual port wastegate fitted can you simply delete the cycling valve. As far as I know it now has no function in my car. Is it simply a case of removing the pipes and plug connector, plugging the pipes that are left for good measure and be done or is there more to it than that? If it can be removed without effecting the car I think I will get rid of mine. If that was the case then Alisdair you can have my old one when I take it out. If you still need it that is mate.
