Well there are different stages of head work you can get done. I stupidly got caught up in doing the 'lollygobbleblissbomb' version and that has cost a small fortune. I can only speak of a few brief times I've had that head on an engine that held together for a week or two (I'm currently into my 5th rebuild [
]) but even on run in miles the head / cam combo felt like a totally different beast. It really seemed to transform from Jeckyl to Hyde once up into the revs. I can only just remember it with fleeting-shrinking brain cells, but it was wonderful. This was on a 3L though. The last version was running at 9psi and 5000rpm limit and with the Vitesse stg 5 turbo, so nothing was really waking up quite yet, but even then you could feel the dragon about to launch. I never got it into the next step as the 4th engine failed at the next dyno session when we were due to up the boost / revs. So that's why the current latest version is in the US getting built under the one roof by one person. Short story long, it's almost done and there has been a lot of changes too, but I'm really looking forward to having that head / cam combo back. We don't realise just how constricted our stock 8v head / cams are. Beware, it's not just a matter of opening up and polishing to the 'N'th degree, there is a lot of tech expertise that goes into a good combo. Way above my head, but there are people you can talk to. Still, the 2.7 is a good starting point and perhaps as an economical alternative, not a bad option comparitively?
As far as doing things in stages, well I'm in two minds about this. On one hand we often don't have the choice not to due to financial constraints and it marries in well with the "Oh I want to see how this all goes in stages" syndrome. I have done both, and in terms of being able to quantify your mods, well sure it is a whole lot easier to do them in stages. I have done a few things at a time and you never know what is doing how much....but the opposite side to this coin is that if you got someone to put together a package that worked together, this would make more sense in a performance (and quite possibly overall budget aspect) concept. I have a friend that is putting together a 400whp kit. I'm not sure what this entails, but it shouldn't be too much with your UK pound, although yes, more than the @60pound valves might cover. [&:]
There's a company in the US that sells a Garrett Turbo with a mount that bolts up to our cars. It's not too prohibitive and might be a good answer to the "Where do I go after the K26/8" question? Might be worth an enquiry?
http://tinyurl.com/cu3cue
