cylinder pressure
- Thread starter smegman
The theoretical value will be atmospheric pressure (14.7psi) x compression ratio (11:1) ~ 160psi. Depending upon mileage, I would think that 130-140psi would be about right. If you're really looking to save costs then I can't think that refacing valves, renewing valve seats, seals and possibly guides on one (offending?) cylinder would be a problem, but it might prove to be a false economy.
Jeff
I don't know how you conducted the test (hot, cold, looking at pressure drops over time, etc.) but if you inject a little bit of oil into #6 cylinder and run the test again and the pressure increases then that would indicate some bore wear.
Alternatively, as you say you can just forget about what's causing the pressure difference and carry on driving as normal.
Good luck!
Jeff
