Cylinder scoring 3.6 engines
- Thread starter bazhart
thirteeneast
chriscoates81
Scoring very rarely affects 3.4's because the head gaskets are different and improve coolant balance inside the engine and allow more to flow through the block.
Baz
thirteeneast
So is it still worth changing the stat on a 3.4?
Thanks in advance.
thirteeneast
You must remember that we will always give honest advice rather than that which will benefit us financially and so we would not suggest fitting the thermostat to 3.4's if it was not strictly necessary.
Also - as time goes by - we sometimes come across and engine that has failed that has cylinder scoring (when we have never previously seen it before in that model) and so may well revise our advice accordingly.
Regards,
Baz
