georgethackray
I've noticed that a few of you have DAB head units. Any recommendations / advice for the positioning of the aerial? I have a Sony unit which has a windscreen mounted antennae with a sticky surface and a black box about 5cm x 3cm in the middle, with the cable attached. The diagram shows it can be attached either along the top of the screen, or down one side.
The problem is I can't mount it at the top, as I have a cabriolet and there's no trim to hide the cable behind, so it has to either be down one side or along the bottom. If it's at the bottom, then the wipers might block the signal.
Also, if I do mount it at the side, is it easy to route the cable up behind the plastic trims?
