Hi guys
I just had my Porsche complimentary check on my Boxster. The servicer came across a problem with the blocked drain pipes. They have now cleared the drain pipes, however, the sponge underneath the carpets behind the passenger and driver seats is damp.
Clearly this needs to be remedied ASAP for two reasons - (1) the car will end up smelling of mould by the time the summer comes and (2) the electronic control unit (ECU) is under the passenger seat and if this gets wet I will end up with a higher cost of repair.
Porsche quote me £1,150 to fix this. What this involves them doing is taking the seats out, removing the carpet and drying with a dehumidifier. I can't see how this should be so much, as it's a little bit of labour and then using them as a glorified car park. Oh, and they said if the ECU does not need to be replaced, that will save £300 or so...so I guess that's an £850 job if the ECU is not replaced.
Has anyone come across this problem? Any suggestions? I was thinking of buying a portable dehumidifier for £150 and putting in garage and letting it dry that way. Although, I have no idea how easy it is to take out the seats and the carpets (and put them back in).
Any advice?
E
Any advice?
E
