Dash lights on
DBA
Spent 5 hours on Sunday refurbishing my power steering pump (89 S2), mind you 2 hours of that was spent trying to get the pump off. When I had put it back together took it for a test drive - and my headlights would not come up, had to manually raise them, then they stayed up.
Thought nothing of this, and planned to look at the fuses/connections today.
When I looked at the car today the battery was totally (ie zero volts) flat.
Put battery on charge (disconnected negative) for 6 hours and returned.
On connecting the battery the dash lit up like it does when you initially turn the key - but this was with the key in my pocket.
I was able to start the car, and it ran OK
When I switched the ignition off it overran for about 5 secs, and all lights came on
Did not have time/light to investigate further. I cannot see any logical link with the power steering pump removal - there are no connectors in that area.
I am currently thinking it could be an ignition switch issue or perhaps DME relay. I have also read that in a 964 this could be a symptom of Ignition coil/lead issues.
I will look at this at the weekend, if anyone can offer any ideas before I splash out on dme relay or ignition leads I would appreciate it
Anthony
Could just be a random coincidence mate. My first thoughts would be the ignition switch. The switch does effect the headlights as I am sure they will not pop up if the ignition is off. I would also check all our your earths. Electrickery can behave in funny ways when earths are not right. Weird one mate don't envy you [8|]
Hi Anthony
With Rob, prob simple fix but a b##@#@ to find, certainly dont envy you with it.
Would check for trapped / damaged wires around the steering pump / lifter motor area as this is the recently worked area, could have disturbed something.
Good luck
Mike
Initial thought would be an earth has been dislodged. Are there any around that part of the engine bay?
Thanks all for the advice. To update on progress:-
I have spent yesterday and most of today trying to track down the problem.
There are no earth points near the power steering pump, and only a couple of electrical connections, so I think it is a coincidence.
So far I have found that if Fuse 2 (headlight motor power) is in place the ignition 15 relay is activated, which lights up the dash, and drains the battery. If I remove fuse 2 everything is OK, apart from the headlight motor.
It looks like fuse 16 had blown (this is for the raise headlight switch), and I raised the headlights manually which in some way has caused the issue now evident. I did not realise that before raising the headlights manually you shoud remove the fuses.
My working hypothesis is that raising the headlights has fed back to somthing. I plan to chack the hazard switch, headlight switch and possibly the ignition switch.
Anthony
That sounds suspiciously similar to my problem, i just spoke to RPM and Oli said sounds like the ignition switch. Im getting them to look at it next week, as ill mess it up more than likely.
