smallspeed
how easy or hard is it to remove the top section of the dashboard?.. this is the bit which is covered in vinyl and goes over the top of the clocks and things directly under the windscreen...
i can only see a couple of screws, one in the lower corner by the drivers door/fuel flap opener, and a couple along the top near the windscreen and through the vent..
Im guessing its also in with clips, so any advice on removing and re-fitting it (without me having to remove the windscreen, as im not interested in that [
] ) would be great..
