Waylander
last week i took the old wreck out for a blast and it was a bit late in the afternoon and getting a bit dusk / dark, some nameless twat pulled out in front of me and it was close, so after a bit of cross white line shouting (as you do) he admitted he did not see me.
so with that in mind and all 968's in Canada are equipped with DRL (daylight running lights) I had a mad moment and decided to look into this as an option.
there is three big issues with this little enterprise,
1 the USA wiring is different
2 the G6 Bridge is also different
3 the relay 944 615 123 00 for CDN (Canada) daylight running lights is NLA and is over £100 as I found one in Germany.
I would still like to do this but make it switchable so they are hidden and only used when I want them.
the Canada DRL put on your fog lights when the engine is running, no side lights or tail lights or dash illumination.
and go off when dipped beam is selected, I don't want to run fog lights all the time so another solution is the project.
so with this in mind i have been shopping..................
First thing needed is a controller for DRL
this will control the function of the DRL.
even dim them when indicators are used on that side of the car,
then on to the lights...
I have bought some of these they are 10w led and 20mm in diameter, I intend to hide these in the lower grill right at the outside edges, I have 4 of them but may only use two.
as my lower grille is just a bit of cheapo mesh it wont matter if I bugger it up.
what do you guys think about this.....................
