De-Cat and MOT
- Thread starter Trap125
If it does - then great news and no worries until next year.
However, if it does fail you will have to refit the catalytic converter (not a difficult DIY job) and then take it back for the retest. They would normally carry out the retest on the area which it failed (in this instance the emissions) - which it should now pass (with the cat fitted).
Have you had a re-map to match in with the cat bypass system - as the only potential issue I could perhaps see might be the effect this would have once the cat was refitted - but as it would only be a temporary measure it shouldn't be too much of an issue.
I am of course assuming that you have a total 100% cat bypass system fitted rather than some of the high flow 200 cell cat systems that are manufactured.
Hope that makes sense
clyde
Apparantly it's a stroll in the park for a healthy 993 to pass the emissions test with bypass pipes fitted and looking at my figures over the years this seems entirely plausible, provided, as D Ward suggests, that it has been re-mapped to suit.
I would give it a go first, got to worth £45 to possibly avoid a lot of hastle, even less if you get one of the cheap specials
C
