De-Cat pipe.??
- Thread starter Big Dave
I imagine they make a big difference because my cab was noticeably quicker over the winter which I fancied was accompanied by a sportier sound. When it came to MoT time that turned out to be a crack between the lambda and the cat and once it was welded up it was noticeably less quick and noticeably dull sounding.
NorthernBloke
I've got the Janspeed back box and decat pipe and the car does spin up much quicker and certainly feels quicker and it's a lot louder than standard (in a good way though) - having said that it's also running a Blitzchip and an induction kit which will help airflow and increase the noise.
I posted a short vid clip on here a while back of the car before and after and other of me going through the gears
Before and After
Through the gears
I think it is fine if you keep the lamda without the cat but he was saying that still more power comes from removing the closed loop emissions monitoring when you lose the cat. I have heard the same from my mechanic too so it should be true.
NorthernBloke
ORIGINAL: Fen
Still got the lamda at the moment Fen so would be interested in the option of removing it - is it worth dropping Richard a note?
NorthernBloke
